Macbook display fingerprint problem, how to avoid it?
Hi sir every tym when i use the macbook the finger print smudges is more on the display how to rid of it sir any recommendations
Hello bro, you may consider this micro fiber cloth to keep in the MacBook bag for cleaning when necessary. it is not possible to completely avoid fingerprints on MacBook display, but simple cleaning methods will help.
Sir whether can we use screen protector ? If we can use it sugeest me good screen protector for MacBook air m2
hi bro, yes using screen protector will be safe choice too. it has to be a very thin screen protector. if its 13.6 inch macbook air model, then you may check this one. suggesting it based on user reviews.
https://amzn.openinapp.co/oaapo
bro suggest me a cleaning liquid
A friend suggested me this one bro. for macbook, ipad display cleaning purposes. its so far good.
