My MacBook Pro M1 is not charging It’s not showing power indicator too, I frequently face this issue, sometimes it will charge. Sometimes you don’t. I took for iPlanet care, there they are telling for checking the problem they will charge ₹3500. So I came back from service centre, can anyone tell how to find the best way as my MacBook is in off position due to no charge.
hi bro, was it magsafe connector you are having issue with? usb c charging works normally?
for diagnostics they normally charge service fee. to identify where the issue exactly they may run several tests. you can call apple support to run free tests otherwise they will guide you to visit service center again if issue cannot be found.
lets give it a try and see bro.
