Hey @iRobinPro ,
I hope you’re good and I’m new to your community.
I want to ask if Buying refurbished MacBook pro 15" 2017 16-512gb is worth in 2024 over other windows laptop under 35k?
I’m a beginner in programming and I don’t have much of budget .
I am also a 2nd year student so let me know if it is wise decision, I’m going tomorrow to get this deal if you could just guide me.
Thanks
Good bro, thank you and Welcome. 2017 model macbook is good to consider in 2024 for average usage. it has faster SSD and processor but macOS ventura current version is the last supported version possibly.
for basic programming works it should be sufficient. are you getting it from a trusted seller or shop? do they provide third party service option too?
