Mac book pro 16 inch M1 pro 512GB variant deal price is 1,70,000 is good to buy or go with m2 pro …kindly give your suggestion
If budget wise M2 Pro fits, then consider latest model always bro. only if budget is not there and you want good performance, then you may consider M1 Pro Macbook Pro model. Whats your usage will be bro? any specific apps requirement or video editing, photo editing works?
Mostly browsing then using some software like autocad and i am normal user not a heavy user bro
M1 Pro model itself good bro. just compare the pricing difference and choose based on your budget choice here. Both models are good for long term usage.
Price diff is around 70 k bro and my budget is below 2L bro
Bro they are saying mac book is new but I checked serial number in apple coverage it shows warranty expires on 21dec 2023 is this new piece or used one bro
I’m confused kindly clarify my doubt bro
Sometimes shows like this while checking coverage in website bro
If the warranty date shows some expiration date, then its already activated product bro. open box or less used may be. kindly check and buy only from trsuted shop or seller. there should be no false information.
for the second screenshot, you can activate warranty by uploading purchase invoice, if the mac bought from proper shop with bill copy. contacting apple customer care will help to do the activation.
Thanks bro
