MACBOOK PRO AIR 15 inch 8GB 512GB for Student Worth Buying?
HI ROBINPRO how are you my sister is studying in college Bsc cs first year laptop vanganum for 5 year use macbook air 15 m2 8gb 512gb spec poduma bro long term use panna na ungalda message panidu solran solli irundan neenga solunga bro edu edukalam bro 8gb poduma foe studying ott movies browsing
I am good bro. thank you. hoping you too. Yes Macbook Air 15 inch will be perfectly suitable for students. 8GB sufficient bro. suppose avanga video editing, photo editing and 3d designing mathiri learn pannuvanga 2 to 3 years la appadina 16GB RAM model edukalamnga. otherwise 8GB RAM sufficient with 512GB storage is good choice.
8gb ram 512gb is suffient for 6years ? still final year of ug and pg couses bro nera os update varuma adu nala laptop slow lag aga chance iruka vedio editing cousela varadu but codings varum web based coused varum bro budget 150000
macOS la swap space use pannitu manage pannumnga, when we do more multi tasking works. athiga chrome browsers, photo editing mathiri works la RAM athigama thevai padumnga. 5 to 6 years normal users ku mac best choice bro. coding pannura platform evlo RAM thevaipadumnu paarunga. athu poruthu choose pannunga 8GB or 16GB RAM venumanu. that will help.
