Bro macbook pro m1 8gb Ram and 512rom 80k is worth with cycle count 60.
Its 2020 model bro. I think price is bit higher. If the seller is open for negotiation you may try to ask for 72 or 73K price range. will make good buy as a buyer.
Sorry not not 256rom it’s 512 it’s that ok
Yes bro. for 512GB 80K is decent pricing as its very less used. are they open for any negotiation? as a buyer is it possible to get it for 75K? else you may consider it for 80K. for 512GB model its worth.
