With M3 chip MacBook expected to launch next week I saw a good offer for 16inch M1 Pro MacBook Pro. Is it worth buying now or should I wait for offers on M2 Pro MacBook?
it is worth buying definitely bro. compared to previous gen models apple always do 20 to 30% jump in CPU and GPU performance improvements every year. so if for your work and budget plan, if you see the 16 inch model suitable go for it.
For next few years usage it should be working well.
Initially I was planning on buying the 15” M2 MacBook Air with 16GB memory and 512 GB SSD which comes around 1.7L I have a seller offering a brand new 16 inch M1 Pro MacBook Pro with same specs same price so I’m confused which one to get.
What will be your work flow will be bro? video editing or designing works?
