Macbook Pro M2 Pro Vs MacBook Air M2, Which is Best Buy?
MacBook Pro With M2 Pro Chip Or MacBook Air With M2 Chip (Both With 16Gb Ram + 1TB Ssd) For Productivity And Mild Games. Which One Should I Go ? Let Me Know Brother.
Both are very well capable to handle even more than what a regular user do bro. you have mentioned good upgrade choice for long term usage. Both can be used for resource-intensive tasks like video editing and image editing as well.
if you need a slimmer profile then Macbook Air is good to consider.
If you need that additional fan setup internally to cool down the machine during video rendering or resource intensive tasks, then Pro model it is.
For your usage Macbook Air seems to be good choice bro.
