Hi Bro,
Could you please suggest me the best wireless/magsafe power bank for Iphone 12 pro except apple product and will it effect iphone battery.?
Also, will it effect battery if we use apple magsafe charger without official/apple magsafe cover or normal cover without magsafe ring?
hello bro, so far many are using it and they are not seeing big change in terms of battery health reduce. it will be gradual and depends on our usage overall. same like wired charging practice, with wireless or magsafe powerbanks also, you have to follow charging practice like when it reaches 20% or around. Do check Ambrane and Stuffcool brands and decide based on user feedback reviews bro.
https://amzn.to/3BrXLxz
Any Qi standard wireless chargers are good to use for wireless. magsafe just helps with the magnetic feature.
Considering any branded chargers will have proper circuit design and protection in place to avoid high and low wattage problems. Magsafe ring provides extra magnetic power and grip bro. if the case is thick or not magsafe compatible, then wearing such ring as mentioned in our channel video will be good idea.
