Monitor For MacBookPro M3 Pro Chip
Hi Bro,
can you please suggest me a monitor for my MacBook Pro?
Usage: Browsing, Coding ( VS Code ), YouTube, and OTT platforms
Budget : under 50K
Size : 27 or 32
which resolution is best ? 2k or 4k bro.
thanks,
Hello bro, I am using two LG 27 inch monitors as I find the size perfect fit for arm length distance kept monitors at my work desk. If you are planning to keep the monitor bit far, then 32 inch would be good choice too. so depends on our work desk length and setup we have to choose the size of the monitor.
So far its working good for me and under 50K budget I prefer this as best buy. Reviewed in our channel too.
https://amzn.to/4a2G3QE
Same spec and in 32 inch size is out of stock currently. So decide accordingly when you need it bro.
https://amzn.to/3P9wtmW
Thanks bro🙂
hi bro, after this, I searched the internet.
but I am still confuesd bro.
if you have time please click the below monitor and choose one bro
  1. you suggested monitor. LG 27UP650-W 27 Inches vs LG 27Up850-W Monitor 27
    • old model but good review
  2. Dell UltraSharp 27 4K USB-C Hub Monitor - U2723QE -
    https://www.dell.com/en-in/work/shop/dell-ultrasharp-27-4k-usb-c-hub-monitor-u2723qe/apd/210-bdzi/monitors-monitor-accessories
    high price but a lot of port ,ips black with daisy chain
  3. Dell UltraSharp 27 Thunderbolt™ Hub Monitor - U2724DE
    https://www.dell.com/en-in/work/shop/dell-ultrasharp-27-thunderbolt-hub-monitor-u2724de/apd/210-bkmc/monitors-monitor-accessories
    everything was good like PPI, port but the 2k display
please suggest me one from above.
i saw many youtube videos, all are saying, 4k monitor scale to 1080p.so 4k or 2k is best,bro
hello bro, with 4K monitor, we wont be using it in 4K mode normally. for readable text and normal viewing we set the resolution to 2K. But being 4K monitor it will be more crisp and clear with texts and images. more colors usually present in 4K monitors with better DPI score too.
So consider 4K monitor and both dell models are good choice and go with one that is released recently and has better USB C features.
ok bro thanks :pray:
@Prasanth6465 Im also looking for a monitor especially the dell ones, could you please share which monitor you finalised and its usage feedback ?
thanks
