My Battery Experience on my 15 Pro Max
Hi , I bought mine at 30 Oct in local Singapore store , now in India .
My Battery Life is Very Poor . My usage is mostly Insta and light games like clash Royale . Probably 1 hr , 2hr in insta , 1hr music apps .
I use 80% Limit , I use them with time space not at the same time , yet it’s very poor .
If I start using at 8.30 and reach home by 1.30pm
The battery’s at under 55%. [Every single time].
I asked the Iplanet service centre (they said to have an backup and we will restore and find the issue)
Is it just my experience or many face the same .
Even my IPhone 11 behaves the same around 85-55.
For a phone like this I must want some good battery efficiency. Yet disappointing .
I still have apple care timeline within dec 28. (So can I buy it ( I keep my phone safe {had IP11 Still haven’t had crack})
Battery Health 100%
Is it normal or what’s your take on this .
Hello bro, when we charge it upto 80% and roam around with different signal strength. especially using data in low signal coverage area for insta or gaming or even for normal internet usage, battery consumption will be bit higher. When you see like overall only 25% consumed from morning till noon, you are good to go to finish rest of the days usage and still left with 20 to 30% battery approximately.
You can follow the suggested charging practice in our channel, which is 20% around and charging up to 80 or 100% as you wanted to use for the next day. Its totally good.
Plus or Max models normally come for 1.5 days under normal usage. again the network strength and type of usage matters here.
Max model iPhones comes with brighter display, 120Hz promotion and bigger battery packed into it can handle the usage very well for 1 full day under above average usage.
So dont worry. as service technician suggested, you may perform iOS Restore once. But consider above possibilities and see if its necessary or not. Any iOS software related bug could be fixed with iOS Restore.
Then you can see how it works for 4 to 5 days and decide accordingly whether to get applecare+ or not. Applicare+ will be useful if you are planning to replace the device within 2 years time or when battery health reaches 80% within 2 years time they replace free battery which costs approximately 13K to 14K for max model I think.
So based on your iPhone 11 battery health you can decide with 15 Pro Max battery health reduce over upcoming months.
Thanks for your suggestion.
And why isn’t that I can’t buy apple care for monthly payments like in other countries. And are there other ways for them , cause I can’t pay like 21k at a time . The usage of my morning routine 8.30-1.30pm is around 45Minutes max , the total usage is only 4-5Hrs including social apps and Yt . It’s behaving only a 10% better than my IP11 battery performance , as a Phone that costs twice the price and performance efficiency, I was disappointed in it ,
Anyways Thanks
At present apple india havent launched any EMI option bro. only when we buy from apple india website during offer periods, we can convert nocost emi method for applecare+ purchases too. other times, its not possible. may be in future we will definitely see such option and that will help more people to opt for it.
agreed about your battery performance case. For continuous usage, depending on the apps we use battery consumption varies.
for example, youtube wont be working in full HDR display mode with iPhone 11, but in 15 pro max when we watch videos in 5G especially, HDR contents do consume more power. if its just music app or other audio content, battery consumption goes less.
We will see improvement over upcoming updates for sure. But if you havent tried any troubleshooting steps, do try performing all settings reset once within iPhone. Make sure to update to iOS 17.2 and check for 3 to 4 days how the performance goes. normal users are getting 1.5 days average. if its mobile data + video then it will be one day usage.
Did Tried them , I’m in Madurai , they don’t have no cost emi for Apple care .
I did had a session with an Apple analyst about the issue via screen sharing , he said it’s normal hence he did said to check to the Iplanet for custom reset and give an estimated date after its usage and report . DONE yet the same .
Do you think it’s worth for apple care cause for that money I could buy an AirPods Pro , I would change the 15 PM in around 2-3 years , so , what’s your opinion
My deadline is at around 10 days from now for apple care (60days)
Buy apple care+ bro, it’s very useful to our product, airpods 2900₹ for 2yrs, any issues happens, get replacement of new one(2500₹/each replacement. And also buy apple care+ for iphone too, back glass durability problem is there, mind it bro.(if u r handling safe, no need apple care+)
Applecare+ is optional bro. for any electronics product we cannot guarantee whether we will be able to keep them safe or perfect all the time. also for any manufacturing defects, we can claim it within the 1 year period.
If we have extended coverage then it also covers any damage we caused and we will pay just small fee instead of full price of the hardware.
So based on the budget and if you feel like its worth considering for your use case, then go with applecare+ bro.
If the display issue is something related to flickering or color changing automatically at times, then its good to get protect+ or applecare+ at iPlanet service center and get the phone replaced before the end of warranty period. that will help.
Hi bro IP15 pro BH-100%, battery fast drain even not used… overnight battery drain is more than 8%
Already u say some trouble I follow nearly 2-3 week.not change bro what can i do bro
