my iPad Air maximum battery health gone to 97%
Hello Mr.robinpro i have bought an iPad Air M2 128 GB WIFI model on 22/05/2024 and it started to decrease maximum capacity of battery to 97% and cycle count is 56 only…. Wat shall I do shall I replace it
hi bro, iPad battery lasts for 4+ years normally. some months it wont reduce and due to bigger battery mAh, you will get that 4+ years of usage. apple replaces battery or ipad only if there is any manufacturing defect. of if you have applecare+ and within 2 years if there is any damage, you can claim replacement.
as we use the iPad, battery gradually reduces and overall it takes time to reach that 80%. you can use the apps required without worrying about battery bro. just around 11th month check battery health if needed. that will help.
Hi bro ,
I’m also going to m2 air in upcoming days .
Did you bought it from online or offline ? .
How it performs on day to day activities, notes taken …
can you share the user experience in this chat ?
Thanks !
Performance wise it is good and battery has a concern it is good pad for daily use and for professional use
How much ?
Is it online or offline ?
Bought in offline….with student offer came around 54999
Iplanet or which store bro ?
Bought in I planet bro
Super bro .
They had given Apple Pencil pro to you at free of cost ?
No bro I think that offer has come just now only bro using student offer I have bought around may month on that time offer was not available
Okay bro
Thanks robin brother
