Bro my iPhone 15 plus just 16days old ,the battery is draining faster ,I have optimised all the setting for battery life but not working.
hi bro, as you can see from the graph, idle time battery reduce is stable and good. during usage it is reducing. as said in our video, if the network coverage is poor and we use internet during that time, then battery consumption will be bit higher.
Dont worry. its new iPhone. continue following the charging practice.
For video streaming purposes drain happens bit faster but being a plus model it will last for one day when you have usage.
If there is an issue in battery then you will see fast drop whether using or while not using the phone.
also upcoming iOS 18 updates will fine tune the performance and battery as well. continue using it bro.
It’s almost a month m still facing battery drain issue on my phone 15 plus Apple saying it’s normal can u help me in this hardly getting 8 hrs usage on heavy
Bro i faced that issue but it is not moblie problem it mental problem because you thought iphone 15 plus have bigger battery time you might saw in youtube or somewhere you need change mind after that iphone use normally you will get good battery life okay don’t blame me what are you telling ? It is only solution maximum screen on time 10 hours you had reached 7 hours and so think about it
8 hours is decent screentime bro. you have less signal coverage as per the screenshot above. using youtube, instagram and spotify music streaming services.
Any smartphone purpose is it serves our usage and requirement bro. even if you choose samsung ultra or oneplus phones, which dont have battery health monitoring automatically, they gradually reduce according to our usage bro.
it’s like you are using a full computer as a handheld device. so it does consume battery power in the background to run all its system services and hardware.
You cannot expect the phone to last more than a day when you have the usage. if there is no usage and you have full signal strength in your area it will give you 1.5 days time.
So 7 hours or 8 hours is really good time with type of usage.
Just charge the device when it reaches 20%. thats the best practice you can do to maintain it. If you start worrying about battery health then usage will be a nightmare.
It will take 2.5 years approximate time to reach that 80% whether you are checking battery health or not. we cannot stop that bro. its applicable for all battery powered devices like iPads, Laptops and mobile phones. I hope you understand.
