My iPhone Unable to Connect WiFi Extender
im using dlink wifi extender when ever i try to connect my iphone to wifi extender it says unable to connect but all other my android phone , laptops, smart tv gets connected but my iphone says unable to connect what to do please help me
Hi bro, Try restarting iPhone once and connect again. If problem continues, then do perform тАЬSettings - general - reset - reset network settingsтАЭ once. this will remove all existing wifi passwords saved too. so check any important wifi network account you normally connect to. then try connecting with the same wifi extender.
It could be temporary connectivity issue.
tried everything as you mentioned above same problem
all my other phones getting connected even my iphone 11 getting connected only my iphone 13 i face this issue
Usually trying this DNS entries method helps to fix any wifi not working issues bro.
But for this DNS method to work, wifi connection should be successful once. You are able to connect to normal wifi router but issue happens only with this extended correct?
ok let me try
bro tried everything still same problem it is saying unable to connect , with normal router no issues only im facing issue with extended router that too only in my iphone 13 i have iphone 11 , samsung tab and more device everything getting connected to extended router but my iphone 13 alone nit :frowning:
This has to checked in person bro. we tried common troubleshooting steps like network settings reset already. why the extender is rejecting the iPhone 13 model only needs ot be figured out by a technician visiting your place. If the iPhone is causing same issue with any wifi router, then we can conclude its iPhone Wifi chipset or iOS related issue.
Trying iOS Restore is an extreme step, but I think thats the only we left out with if you want to use the extender. its the last troubleshooting step to fix any software related issue causing the problem.
