Hi bro, recently my macbook got drenched in water. little amount of water gets internally. it was very upsetting that the screen replacement may cost around 45k. my laptop works fine there is no problem in the audio jack also, still worried about something may goes wrong in future,I followed your youtube steps its been two days the water isnt dried from the screen .please help.
Hello sis. Sorry to hear about that. I hope you are referring to this video.
Additionally, you may use hair dryer gently to blow on the display and drain the water that are visible.
*Avoid using the display continuously as it may damage it even more.
Depending on the level of water damage it may take time to dry.
