yes bro
Ok. Then do check in mail app menu system bro. if you are unable to find it, kindly visit nearest apple service center. a technician will guide you and fix any problem if its at software level. for some problems it is must for a technician to inspect the unit in person.
app store update it arrives i will update fast its problem wating update
suppose problem update ku apram fix agalaina once service center visit pannidunga bro. it will help.
iphone 15 plus have nfc not showing bro
i have nfc sony amplifier when go detect
NFC in iPhone cannot be used for music sharing or files sharing purposes bro. only NFC enabled shortcuts or few functions can be used. explained in this episode.
Advance diwali bro
my iphone nfc toggle
Happy diwali wishes to you too bro.
my iphone heating up while using airtel
what i can do bro
iam updated also bro
Kindly visit apple service center once bro. iOS Restore thevaipadumnga.
it coming ios 17.1.2
and heating while using airtel app
Hi krithik, did you perform iOS Restore? visited service center?
ios 17.1.2 when will
may be today or this week expected bro.
ios 17.2 when will come
ios 17.1.2 having glitch screen
on your new iPhone 15 Plus model krithik? if its software issue then performing all settings reset will help fixing the problem. if not fixed as the phone is under warranty, its recommended to visit apple service center krithik.
Also for new Question, kindly create separate discussion post with suitable title.
