Nano texture or standard display on Macbook Pro?
Shall i go with the nano texture display on the mac book pro 14 m4 does the display colour or clarity will change what will be your suggestion
By applying the student offer and get airpods how much can I resale and where
Thank you
Hi bro, nano texture is similar to matte finish display. it will cut down the glare but very small difference with image quality overall. if you are in a bright environment most of the time, then consider nano texture is good idea. otherwise go with glossy regular model bro.
Resale value depends on when you are going to sell it in future. normally used macs see big difference as many people want to go for under 1 lac when they plan for used mac models.
So choose the mac based on what your usage is going to be and when its time to change the mac, you can sell it to shops or sellers in future and go for upgraded one.
Bro Just now I bought a MacBook Pro M4 in standard display. I don’t know what are all the products to use. Just now I have ordered the Tomtoc Defender Sleeve and Barrot Cleaning Kit. What are all the things I need to order further? Can I use the Keyboard Protector? Hardshell Case? Screen Protector?
I heard that it will damage the screen i saw some old mac got keyboard marks on display? If not, what product can I use? Suggest something at any cost (budget dosen’t matter to me ) best quality
I saw your video about it pls suggest me some
Congrats on your new macbook pro. we can use any thin type screen protector. suggested cheaper options and branded like spigen or esr can be considered too when it comes to screen protectors.
But we have to choose the one that is super thin.
Saco brand provides cheaper but decent quality protectors bro. you may check this once.
make sure to apply it in a dust free room or you can get assistance with any computer service person or shop who have experience with screen protectors applying. to avoid bubbles and issues.
