I’m new to iOS and need your advice on whether to go for the iPhone 14 Pro Max or the latest iPhone 15 Pro. I’m leaning towards the 15 Pro, but I’ve heard concerns about heating issues, especially in the 256GB variants. The 14 Pro Max is an option too, but I’m hesitating due to its slightly heavier weight. Your insights and experiences would be invaluable in helping me make the right choice. If you think there’s another model worth considering, feel free to suggest.
@iRobinPro bro if u are reading this, please share your thoughts on this.
Hi bro, 14 Pro Max is bigger and suitable for above average users. If you are an average user then 15 Pro from your list should be perfect choice. its also lesser weight compared to 14 pro max. almost 40 grams less which makes big difference while holding and using it for long time.
If you have bigger hands then 14 pro max or 15 pro max (20 grams lesser than 14 pro max) will be perfect fit.
Its good to experience the device once at apple showroom as hakkim bro suggestion. so you will get best idea while using it for few minutes.
Heating issues are fixed with software updates already. I have checked with my friends using 15 pro and 15 pro max, they are not noticing any heat or overheat for normal every day usage. During fast charging and while using camera app or gaming heating is normal. its managed automatically too.
You can choose between one of these choice you already have based on above points bro. Let me know if you have any more confusion. happy to help.
