Hi bro, ipad air m2 new ah purchase panniruke, charging practice epdi irukanu…? 80% limit on pannikiten but 81% chrge aagiruku how? Battery health ah nalla maintain pannrathuku ena tips follow pannalam? Nd new ah os update 17.7 iruku or 18os also iruku edu update pannrathu bro… Main ah pencil epovu magnet la connect pannrathu ok dhana… Epome charging 100% nu kaatuthu
its same as iPhone bro. not to drain frequently is the object and charging around 10 or 20% will be helpful.
optimised charging also there on ipad. so totally according to your usage requirement you can charge. its bigger battery unlike iPhone bro.
iOS 18 update pannalamnga if you want to experience new features. otherwise you can stay in iOS 17.7 just to receive bug fixes and security fixes. choice is totally yours.
new iPad so charging difference irukumnga. neenga use panna panna adjust agum.
Then what about pencil pro? Epome magnet la connect aagirukathu onu ilaye athoda battery health edu affect pannathu thana?
so far issue irunthathu illainga. also use pannathapo disconnect pannitu safe a pouch or bag la vainga. bend aagidatha mathiri pathukonga. keep the bag safely bro.
Bro ipad air M2 box la koodutha charger use pannre ana 20 to 80% charge aaga 1:30hrs mela aaguthu yean😵💫
initial la unga usage poruthu charging pattern difference irukumnga. next few weeks la it will improve. optimised charging feature takes care of managing battery and adjusting speed of charging bro.
Hi na, ipencil pro vachiruke 2 times kitta keela viluthutu… idhanala ipo varaikum oru issues ila ana keela vilutha edachu problem varuma.
mudinja alavuku drop aguratha avoid pannanumnga bro. exact a solla mudiyathu, sometimes first time la ye pencil damage agidum internal la. so take care here after to avoid any issues.
Hi bro, Naanum iPad Air M2 11 inch wifi base model vechirukkan. Once enakkum 81 percentage charge kaamichuthu, but athukku aprama illa.
Same bro, naa intha post read panna aprama than pencil pathi nenaikaran. Naa eppovume pencil iPad la attach panni than vechirupan. Ippo varaikkum no issues faced in 8 months usage bro.
