I am using iPhone 12 128gb variant
NFC option is not working , it’s not showing in settings also ,last month only I am trying to use
But it’s not adding my room nfc card
Can you help with this bro
And
My phone battery draining to fast
1yr and 1 month of using my phone and now my battery is 87% only
Hello sis, NFC is not open to all applications in iPhone. its restricted for security reasons. We cannot use it like we do in android. Explained in the following episode.
Which NFC Card you are using? kindly share the product link if you can find the same on amazon.
Regarding battery drain, make sure to update to latest iOS 17.2.1 which also comes with battery drian fix. Then follow these battery saving tips, and that will help to get better battery performance. Observe for 4 to 5 days usage after trying following suggestions and let me know how it goes.
