Hi i am using iphone 13 pro max today i have battery issue without using my mobile phone and i checked battery and i found new like No mobile coverage that has 40% can i know what is these ? And please help me with is problem. Thank you.
hello bro, do you stay in no mobile coverage most of the time? if yes then you can use airplane mode to avoid network search. when there is no network and searching does consume battery power. you can avoid that by using airplane mode.
Thank you for your response. Whether it will effect the battery percentage are any other issues.
it wont affect battery health bro. considered as normal usage only.
