Noise Control in Transparency Mode
Hi bro .!. Bro first Elam AirPods transparency mode la below 80 decimals la maintain agum when will are in a noise environment but ipo noise cancellation mode turn on pannuna tha below 80 poguthu and transparency mode la 80-90 la maintain aguthu … Epidi bro below 80, transparency mode la use pannarathu ??
Hello bro, hearing affect aaga koodathunu recent firmware la change pannirupaanga. volume adjust pannuneengala in transparency mode? and particular audio playback ku antha mathiri aguthungala with apple music content or youtube audio?
Transparency mode decimal level or volume adjust panna mudiyuma bro… ?? Particular content Ila bro … Namma oru vela noise high la iruka environment la irutha transparency mode la Namma desired decimal set panna mudiyum ? Content listen panra Mari irutha noise cancellation use panna some what ok bro … but noisey environment la yaravathu kuda pesa transparency use panna I felt like I was without an AirPod and noise full la iruku …
Normal volume control oda connected a irukunga. manual controls ippo possible ilalinga.
during phone call conrtol center la voice isolation ON pannirukeengala?
Yes bro voice isolation on la tha iruku …
OFF Pannitu check pannunga bro. usual la voice isolation surrounding noise a cut pannum. some users report radio like voice or issues. so in such cases off panitu check pannunga for few calls. you will see the difference.
