Hi Bro , Phone Call Voice Isolation Not Working . Opposite side person is able to hear the noise in the environment . Before the iOS Update it was working properly but now it is not working as before. Suggest me some Troubleshooting Steps bro.
Hello bro, are you noticing this issue after iOS 18.4.1 update?
Yes Bro .
So far no reports from fellow users bro. I will check in my device and friends device to see if the same problem appears or not. meanwhile you can try restarting iPhone once and check voice isolation is working or not.
Im also facing same issue in
Do perform settings - general - reset - reset all settings once and check if that helps bro, make sure voice isolation feature is ON during phone call from control center.
