Picture in Picture mode Not Working in iPhone 14 Plus
I’m unable to use picture in picture mode while having video calls. I enabled pip mode in settings. For example, I’m doing video calls using whatsapp, imo, botim and when i close the app the video itself closed but I can listen the voice and respond too.
Usually in android if we close the app while doing video calls, the video will appear like a popup and we can use other apps as well. Kindly give me the solution.
If the app we use enabled with iOS PiP mode then it will work bro. For example you can see that youtube app allows us to use pip. Similar to that, whatsapp and other video calling apps have to roll out that feature. Else we wont be able to use it.
Currently picture in picture works with facetime.
