Hi bro … past 2 days ah intha mari Pink Vertical line varuthu enoda iphone 13 la. I am using IOS 17.3 ithu enna pannalam bro ?
hi bro, ithu software issue illainga. display hardware problem. service center la check pannuna display replacement thaan ore option a irukumnga. side portion la pressure athigama apply agirunthalo or water contact or drop agirunthalo intha mathiri display module behave pannumnga. should be checked at service center to know exact issue and replacement options bro.
oh okok bro… Thanks for the reply … actual ah mobile endha ah physical and water damage edhuvum agala automatic ah vandha issue and also mobile out off warranty la iruku. So oneplus mobile ku lam display replacement panra mari intha mobile ku replacement kudupangala ?
as mentioned in our iPhone 13 Green Screen video, full green screen issue ku currently free or 2000Rs serivce fee based replacement pannitu irukaanga bro. so ethukum once apple service center la check pannidunga. diagnostics la namma ethuvum internal damage pannalainu conform aachuna software update ku apram thaan ippadi aachunu solli paarunga. but service center person naala approve panna mudiyathunga.
so talk to apple support with case id. explain the problem happened after software and mention in iPhone 13 model and need approval to get free display replaced.
neenga ethuvum drop pannalai appadingrathayum mention pannunga. no damage from your side as proof of service center can be seen.
Try pannitu sollunga bro.
