Possible to take backup of telegram chats?
Hi Bro, hope you are doing great and thanks for answering each and every questions and doing the great job. Thanks once again
My question is will it be possible to take backup of telegram private chat alone and not group or channel chats from iphone 14pro max and restore back to iphone from cloud just like whats app
I am good bro, thank you. hoping you too. Telegram uses cloud storage to backup data bro. we cannot manually take it for particular chats. they backup everything. just telegram group chats once clear pannidunga. then try to restore telegram on other device you want to use.
even full iPhoen backup and restore pannalum telegram data include aagumnga. so manually after deleting telegram group chats, private chats mattum restore aagum bro.
Thanks bro, also eppadi Namba Ella apps user ID and password save pannuradu in Iclould. Edhachum specific settings irruka. Ipa Naan phone factory reset panna all apps password save panna mudiyumaa.
Also any app to backup sms as sync of my messages are not working checked with apple service center as well but no use. So advice any good apps for backup and restore
welcome bro. under settings - your profile - icloud section la supported apps toggle irukumnga. entha apps data neenga icloud backup edukanumnu irukeengala intha toggle ON la vaikalaamnga.
in iPhone, only iCloud backup works well bro. third party app sync and backup antha app provide panniruntha use pannalaamnga. otherwise icloud service thaan use pannanumnga bro.
whatsapp icloud backup and restore option kudupaanga. phone change pannurom and whatsapp backup restore pannanumnaalum ippadi pannalaamnga.
