Powerbank for iPhone 13 and aslo Wired headphone
Hi Robin Bro
How are you doing, could you please Suggest me a good power bank for iPhone 13 and also wired headphones?
I am good bro. thank you. hoping you too. any branded power banks can be considered bro. Ambrane, URBN etc., use it with original or MFi Certfied lightning cable always.
https://amzn.to/3My1lvf
wired headphones are not available at present bro. lightning headphones are available only with apple.
They have 12-watt fast charging and 22.5 W super fast charging and also 10000 mAh and 20000mAh
which one you will suggest bro.
10000 mAH will be safe bro. mostly suitable for travel purposes too. I think higher mAh may not be allowed in Airplanes. so you can decide accordingly.
Bro iam having iphone 12 and 5g on there is an heating issue and rendering using games
hello bro, any specific games you are playing or using VPN while playing games and noticing such heat? while using 5G heating will be there, also due to current summer season our room temperature have increased than before. so all electronic devices are heating up than normal level. that could be main reason why you are noticing such heat while using 5G or Personal Hotspot or while Gaming and Video Recording using Camera App.
That wont affect device,but depending on the game and its servers availability we will notice such lags mainly due to High Ping too.
Thank you bro for your advice.
