Powerbank for iphone 13
Hi bro,
How are you ? Could you please suggest me a good powerbank (10kmah and 20kmah) for iphone 13.
Budget is under 1.5k
I am good bro. thank you. hoping you too. URBN Powerbanks are good choice to consider.
Okay bro
Thanks for sharing . Added to my cart !
MI brand power banks use panulam ah bro
iPhone 13 ku nala case suggest panuga bro
Budget under 500rs
use pannalaamnga. namma audience la ye use pannitu thaan irukaanga.
amozo case for iphone 13 is good one to consider bro.
okay bro. Cover okay
I will share the mi power bank link - pls check and confirm bro
sure bro.
Bro
Xiaomi 20kmah (Price - 1900) - Xiaomi Power Bank 4i 20000mAh 33W Super Fast Charging PD |Smart 12 Layer Protection|Type C Input & Output|Triple Output Ports|Supports Android,Apple, Tablets, Earbuds,Watch(MI Powerbank),Black : Amazon.in: Electronics
ambrane 20kmah (price -1300 ) - Ambrane 20000mAh Powerbank with in-Build Type C Cable, 22.5W Fast Charging, USB & Type C Output, Power Delivery, Quick Charge for iPhone, Android Mobile & Tablets, Earbuds, (Stylo N20, Purple) : Amazon.in: Electronics
urbn (20kmah price - 1400 ) - URBN 20000 mAh Premium Edition Nano Power Bank | Two-Way 22.5W Super Fast Charging | Pocket Size| Dual Type C Power Delivery (PD) Output + 1 USB Output for Quick Charge (Black) USB Type-C Input : Amazon.in: Electronics
urbn (20kmah price - 1200 ) - URBN Lithium_Polymer 20000 mAh 22.5W Super Fast Charging Ultra Compact Power Bank with Quick Charge & Power Delivery, Type C Input/Output, Made in India, Type C Cable Included (Camo) : Amazon.in: Electronics
xiaomi (10kmah - price 1300 ) - Xiaomi Power Bank 4i 10000mAh 22.5W Fast Charging PD|Smart 12 Layer Protection| Durable Steel Casing |Triple Output Ports|Supports All Phone(MI Power Bank),Black : Amazon.in: Electronics
URBN 2000 mah is best in this list bro.
Which one bro ?
  1. Nano power bank - URBN 20000 mAh Premium Edition Nano Power Bank | Two-Way 22.5W Super Fast Charging | Pocket Size| Dual Type C Power Delivery (PD) Output + 1 USB Output for Quick Charge (Black) USB Type-C Input : Amazon.in: Electronics
  2. This one - URBN 20000mAh 35W Turbo Fast Charging Power Bank | Dual Output | PD + QC Compatible | Two-Way Fast Charge | Pass-Through Charging | for MacBook Air, iPhone, Samsung, Android & More (Blue) : Amazon.in: Electronics
35W second option is bigger one. if you need nano model for smaller and compact design go with Nano power bank bro. If size isnt an issue then for 35W fast charging you may go with second one.
I am using nano powerbank and so far its sufficient for occasional usage.
okay bro.
I go with nano powerbank.
ask.irobinpro –> Intha mari question & answer platform epd build panurathu bro .
I have few set of audience for me ! so am asking bro. If possible, share some inputs bro !
I am using discourse forum software bro. You can check both hosting and installation with digital ocean bro.
Youtube videos ithu related a refer pannunga. maintenance mattum pathukanum to avoid data loss. mostly manual hosted solution bro. already website hosting experience iruku na itha learn pannitu implement pannalaamnga.
