Protection case for macbook air M4 ?
Protection case necessary for macbook air M4, can you suggest bext quality case for macbook air ?
hi bro, its optional. depends on previous experience with laptops we used and if we have any thoughts about damaging the device outer body by dropping or hitting with other objects while working on laptop, then case can be considered.
screen protector is essential is what I understand. to avoid oleophobic coating wear out over long term of usage.
