Hi bro
Is it good choice for using protection pro instead of tempered glass on iPhones and is it safe for screen protection.
Hi bro
I havent personally tried them bro. Lets wait for our fellow users suggestion.
Received two comments from our audience bro,
Manigandan V - I’m using for my iPhone 14 plus and oneplus 10 R. It’s amazing . Comparing to tempered glass it’s really good in Touch wise as well. It’s looks amazing in ProtectionPro. But readymade protection screen is not that much good. If we put customized screen protector with worth 600 to 1000 it’s great. There are 3 layers, 7 layers and 12 layers screen protectors are there. We can use anything based on our budget. I’m using for 600 Rs.
Dinesh - I used to use it earlier but since it’s not that resistant to scratches and I do have long nails it’s getting teared for me easily.but the drop protection is just! I’m now using the D+, 6d or whatever they call as high quality tempered . It’s good for the 150rs price bracket.
