Hi, iPhone brand new setup pannum poathu initial charge evalavu neram pannanum?
Illa normal a use panra maathiri use panraya
Pls advise
I bought iPhone 13 128 this Friday
It’s on iOS17.2
Pls advise
It’s on iOS17.2
Hello bro, there is no such charging recommendation set as iPhone batteries are Precalibrated in the factories. You can start charging upto 80% or to 100% and start using the device normally.
Congrats on your new iPhone by the way. ![]()
Are you sure bro?
Bcuz normal a use pannitu ikum pothe battery drain aahuthu
That’s why I worried
First phone eh setup pannitu 100% charge pannen after that I’m following 20-80% charge
But normal eh vida koodaya battery drain aahura maathiri irukku
Yes br. new phone ku background optimisation aagumnga. according to your usage. battery page la last 24 hours usage graph paarunga. share it here and it helps to understand better which app or service consumes more power.
I’ve sent brother @iRobinPro
Can u check it out pls
Graph looks stable and perfectly alright bro. continue following the same charging practice and use it as you want to bro.
Ok bro thanks
