Unsure if anyone is having this issue or not. Whenever I use phone for payments and select option as CRED or GPAY or anything, it redirects to me GRT app by mentioning the message stating, “wants to open GRT”. I don’t know whether it’s problem only with me or anyone using it has the same. I didn’t test by uninstalling GRT but want to know before I do that.
hi bro, GRT is not a banking app and so far no such reports from our fellow users bro. issue could be specific to your device.
is iOS 18.4 updated? all gpay and cred apps updated to latest version?
Yes bro. I keep all updated always. Even that sounded weird to me. I don’t think this is specific to ios too. Need to uninstall that grt app and see if issue resolves
Do try it bro.
Any other option than uninstalling the GRT app? i am facing the same issue
We can select default apps for other apps but not possible to do it for payment apps bro. this is strange issue. can you try performing all settings reset once and then try opening gpay from other app to make payment? trying ordering something in zomato and select gpay or cred. let Me know if issue fixed or not bro.
