Hi Bro, Greetings, Recently I bought Iphone 13. Can you please advice a good earphone (Wireed & Wireless) other than air pods. I used the 2k worth apple earpods which is irritating my ears. I does not fit in my ears, Can you please advise on this
hello bro, if earpods are not fitting properly or not comfortable then getting airpods wont be good idea bro. Do you find in-ear type headsets suitable? comfort level should be checked.
JBL Brands have decent headphones in terms of Price and Audio quality. you may check on amazon for JBL headphones bro. Their Tune series around 1000Rs budget. Check user reviews and make final decision bro.
