Control centre & Instagram glitch and flickering is still happening - should i update from normal version to beta version to avoid glitch and flickering
hi, update to iOS 26.5 and you will see most of those glitches are fixed. it is much smooth and better now.
I have updated them but still i see the glitches in control Centre ,Instagram, setting and when i see the phone is lagging is lagging or glitches appears to be more i force restart and then the phone we will okay with minimal glitches , should i need to contact the i care again
i also having this issue still in 26.1 ios iphone 17 pro max while receiving all calls and outgoing calls
noticing the same control center, instagram glitches in iOS 26.5 bro? or only during calls?
In Instagram, setting and zomato , swiggy and control centre
is the iOS updated to latest iOS 26.5 version?
no bro still all are facing the issue screen flickering while on all calls
Yes bro IOS has been to the latest version and also i dont use the beta
after updating to latest 26.5 I have stopped seeing the flickering issue on all other apps. as hakkim bro pointed out only in calls screen due to contact poster bug we see such flickering for a second. its minor issue though.
Perform all settings reset once and see how it goes bro. if the issue repeats we have to visit service center. after taking backup they perform full iOS restore and then restore backup to see if issue fixed or not.
Hi bro
In my iphone 16 pro i am having flickering issue during incoming and outgoing call even after 26.6 ios update
Good morning bro. Is the flickering happening on other apps or only on incoming caller screen?
Bro it is happening only on incoming and out going calls sometimes not all times
I understand bro. possibly a bug still present on the iOS Software level. as its minor issue apple did receive lot of reports regarding the same. expecting fix in upcoming updates only. if its not bothering much and dont worry it wont affect the device hardware by any means. in iOS 27 beta 4 i am seeing the issue not at all happening in caller screens.
So give sometime we will see it getting fixed soon.
