Hi bro en friend olx la oru iPhone 13 vangunan oru 6month use pannan. Apram mobile ah reset pannalmnu panni irukan apram eillayaiyum safe ah off pannitan apple id signout and findmy mobile eillathiyum off pannitu reset pannan. Reset pannitu set up pannum pothu. Remote management nu onnu varuthu ena pannalaum ulla poga mudiyalaa
hi bro, enterprise or company iPhone a irukalaamnga. within settings - general - vpn & device management - company profiles ethavathu install agiruka nu paarunga. try to delete it bro.
Ulla poga mattuthu bro. Microsoft mail id kekuthu. It’s owned by nu some name kattuthu
Device enga buy pannathunga bro? any mobile shop? enterprise unit sell pannirukaanga. you should get clear mobile phone without any MDM profile installed. remote la company device lock pannirupaanga. so neenga ippo login panna mudiyala. apple service center la ethuvum panna mudiyathunga.
third party service center la once check pannalaamnga bro. are you around chennai?
No bro mobile olx la vangunathu. Na madurai bro
oh ok bro. seller ungaluku inform pannama sale pannirukaanga. namma used iPhone video la solliruntha mathiri tips eppothum follow pannanumnga. while buying used iPhones. at present third party service center la phone oda MDM remove panna mudiyumanu check pannunga. thats the only option available bro.
