Renewed AppleCare Coverage ipad
Hi brother ipad 9th Generation wi-fi Renewal AppleCare Rs:3499yr Either way better than another decision now. any suggestion Brother?
hi bro, iPad 9 is still a good device. applecare+ is an advantage to claim new iPad 9th gen if there is any damage happened for next one year. otherwise it also helps with resale value if you are planning to sell it in next few months. check the pricing of used iPad models once too.
experience the latest iPad 11th gen at showroom once. if you feel the difference then consider an upgrade bro.
Else renew the Applecare+ and continue using the device bro.
iPads normally lasts 5 years maximum with its battery life. applecare+ helps us to claim new iPad or sell it with better resale value bro.
