Hi bro ,
Currently i am facing ringtone issue… like i am getting ringtone song for a caller but it automatically mutes the song and only vibrating…
Hi bro ,
Hello bro, its a known bug for some users. I too, experienced it with custom ringtone. Have you tried setting up default ringtones and see whether it stops after one ring or continuously rings?
I have not tried with default ringtones
Ok bro. try it for 2 to 3 days usage and if there is no auto cut off after 1 ring when you receive incoming calls, then its clearly iOS 17.2.1 specific bug. which will be fixed in upcoming update.
