Safari Full Screen shows Line, How to Fix?
hi
when I do full screen of safari I get this line.
minimize then full screen, line goes
I face this only in safari
please advice
Its happening only with Safari browser or other apps also bro? also safari is in full screen or normal view? when this line shows.
hi bro
this happens only in safari with Full screen mode.
not happening in other apps.
Previously you had similar issue correct bro? We had similar discussion? happened only in full screen mode?
ya correct.
only safari, only in full screen i get the line
once i minimize and the make full screen it goes.
is it safari issue or display issue please advice
I tried to recreate in my macbook and mac studio, but so far nothing like that happening. this could be minor bug. have you updated to latest macOS?
yes bro, latest version only
Try reducing the zoom level with Command + key or Command - key and see if the black bar disappears bro. else do visit apple service center once and check whether it can be fixed or not. this mostly looks like software bug.
