SBI security draining battery and heating
SBI security app draining more battery as well as overheating even minimum usage of 5~10 minutes in 15 pro max
hi bro, is the app granted location services, mic and other access? can you try limiting the permissions and check? but if the app needs those services to run normally, we cannot restrict them. but check GPS and then check bro. could help.
