Screen Guard for Macbook Air M1
**bro how is the
mba m1
now I had saw your old video about the screen of macbook air m1**
Hi bro, are you looking for screen protector for Macbook Air M1?
yes bro, i bought macbook air m1 on aug 3 , i am also using saco screen protector many people recommending to remove it.
as I said in the video, using it with keyboard sleeve may not be good idea bro. may I know why people recommend it to remove screen protector? are you noticing any quality problem with texts, photos and videos you see?
no bro not at all a problem… with screen resolution
Is your laptop fine by using screen protector
Yes bro. I recently sold my m1 macbook air and moved to m2 macbook air 15 inch model. Got new screen protector and waiting to apply and record video for it. I shared my personal experience with so many users across the web had similar oleophobic coating wear out issue.
Too much glare is one problem when we go with poor quality screen protectors. so checking reviews of some and picking up one will be good idea.
If someone saying that its not good to apply screen protector, need some proper explanation what level of damage it could cause if we applied it, will help us understand better.
what your opinion either I remove screen guard or keep it
thank you bro for fast reply …:smile:…
I am keeping it bro. I have suffered that wear out problem with my 2015 macbook pro 15" model. my brother experienced same issue. So I am not going to remove it unless any valid reason given. either by apple or by the person who asks to not to wear it.
bro macbook screen protector brand sollunga purchase panna
Spigen Brand, Saco or Moca brands consider pannalaamnga. search on amazon bro. if you cannot find it for your model, then local shop la very thin type screen protector custom cutout pannitu use pannalaamnga. display is very expensive, so safe a handle pannunga, experienced shop person kita kuduthu screen protector apply pannalaamnga.
Found below reasons in youtube. Pls share your opinion bro. Will be most useful :pray:
When we remove the screen guard, the anti glare coating is also getting removed along with the screen protector. From below youtube link
In other case, the screen protectors remove the function screen layer as well. The youtube link below
hi bro, I am really wondering about the type of adhesives used in this case. I havent personally checked by removing the screen protector yet. But while applying I have removed multiple times and the adhesives are not that strong to remove the coating too. its just like iPhone screen protector.
If we remove it the adhesives wont be affected. may be avoiding some cheaper screen protector is recommended. that uses some strong or poor adhesives.
Thanks bro. Im going to buy the saco brand screen protector then. Thanks for your reply
Welcome bro. apply it carefully in a room where no dusts. or checking with any experts at mobile or computer service center to get help with applying without air bubbles also good idea. they may ask for 50 or 100rs for such process.
