Screen orientation (auto rotate) problem
Hi bro, hope you’re doing well.
I’m using iPhone 13 with iOS 26.1. Recently I’ve started to notice that my phone’s auto rotating feature is not working (my screen does not go to landscape mode when I turn my phone while streaming a video in any ott app or YouTube). I checked enabling and disabling the screen orientation button, also did reset all the phone settings. It works for fewdays and stops working, I’ve to restart my phone every time to make the auto screen orientation to work. But while using camera app it works always fine. I’ve always called several times to technical support, even they’re unable help me. Please help me understanding this problem is it a hardware or it’s a glitch??
Hi bro, within settings - accessibility - per app settings page do you have any apps added in the list?
No apps bro
as you have already performed all settings reset, its recommended to do iOS Restore once and check bro. its mostly software issue and not hardware side issue.
take full backup and then perform iOS Restore to clean install iOS software.
Then you can restore the backup to get all the data back on device storage. this will fix any such issue related to software settings bro.
