Screen Protector for Macbook Pro, Which one to choose?
Hi , I have watched your video on applying a screen protector on the MacBook. But in that video you told that 9H hardness is not allowed to use. But most of the products and the one you gave in description has 9 H hardness (Saco). I do have a MacBook Pro 2019 16. My doubt is whether I can use the Saco 9H hardness screen protector.
Thank you for sharing the question here @akshath . Finding a thinner screen guard is hard these days. Not enough stocks have been maintained by the sellers recently. We can go with 9H but avoiding the keyboard silicon sleeves is a good idea. Otherwise, MacBook lid will not be completely closed and may affect the sensor that automatically turns off the display when the lid is closed.
There are more hard screen guards available in the market, and that’s why I suggest people consider them as thin as possible, as the purpose of the screen protector is to avoid the keyboard layout getting printed on the display. Which could result in an oleophobic coating wearing out the problem.
Also Saco brand is perfect to go with akshath. I am using it, and so far, it’s a good fit.
