Hi Bro,
Can any one suggest the short lightning cable mainly for the power bank charger
Hi Bro,
Amazon Basics cable or any MFi Certified cables are good to consider bro. But unable to find short cables right now. regular 3 feet cable and less than that size also priced same.
You may check with other MFi cable options too bro.
Thanks bro ,
But main usage for me is to charge the mobile from powerbank. I have found few, let me use it and will update here bro.
ok bro, try any mfi cable that should be safe to use.
Bro iphone 15 pro i am using original cable and adapter while charger phone get heat, if i samsung cable mean phone not get heat bro. What can i do bro?
Is there any problem
during fast charging the phone normally gets heat bro. that is normal and wont affect battery. it automatically adjusts heat level when charging. samsung charger may be giving lesser watt power and that may not cause such heating. if the charge speed is ok for you, then you may continue using samsung adapter. as yours is iPhone 15 model, any branded or original usb c cable should be working good.
Ok bro.can I continue Samsung cable for charger.
Yes bro. as its USB C cable its no problem in using third party branded adapters. only if you see slow charging or any other issues, then you may switch to apple adapter. else continue.
