Bro after 18 updates iOS location option not show settings pls location on off short cut need
Hi bro, within shortcuts app you are unable to see Location option? Did you check inside Automation Tab?
Ethu apdi bro pakurathu
within shortcuts app - automation tab irukumnga. athula shortcuts create panna try pannunga. if you see location option to use with automation and shortcuts then it will work bro. otherwise not possible.
