Software update 16.4.1 Heating issue
Hi robin bro, I using iPhone XR from last 3 year i have an issue after update the 16.4.1 it was lot of heating my phone, when i using 5 to 10 min, after that heat will be not reduced 10 to 15 mins. any solution? @iRobinPro
hello bro, whats current battery health percentage? also due to current summer season, most of our devices are getting heat. during charging and while using. mainly because of increased room temperature electronic devices are getting more heat internally and takes time to cool down.
If the heat is abnormal we can do iOS Restore once and check. if its software problem that will help fixing it.
Hi bro, Thanks for responding, My phone BHP 84%. I not facing heating issue while charging bro.I faced heating while using bro. As you said current summer season. But, I updated 16.4.1 a week before only bro, there before update i not facing heating issue like now what i getting, I used more than 30 mins it warm only but now it heating is high too.
I understand bro. you can perform ā€œSettings - General - Reset - Reset All Settingsā€ once and see how it goes while using. there is a chance to see good difference in heating as few of our users also experienced the same.
Sure bro thanks. I will do it.
