Hi Bro
Before I subscribe spensio I would like to know the capabilities of spensio that can i spensio synced with my wife phone also so both of is can update the expenses and income together
Hi Bro
hello bro, spensio icloud sync feature is there, but it works with the apple id. if two iphones uses same apple id then the app data also synced. if they use separate apple id, then sync is not possible bro.
the app aims for individual finance expense tracking purposes at present. not suitable for group or family expense sharing as we use individual apple id based icloud sync feature.
Kindly let me know your use case.
Hi Bro
My requirement is to have family budget expenses are updated by my wife and myself at the same time for better visibilty on overall family expense tracking.
Regards,
Maheshram G
I understand bro. will consider this type of family shared setup in future versions. but right now improving the existing app functionality and working on sms, email capture of expenses. will definitely see how its possible to add such family based data sharing setup.
