Bro im using iphone 13 While in party I accidently spilled little bit of alcohol on my phone and after that i suddenly wipe it off .does this cause any damage to the iphone?
water damage is based on density of water bro. but most of the time we dont see water damage due to the water resistant. so dont worry, continue using it and if you are not seeing any display color change or speaker, mic issues. then not to worry.
