Storage adapter or storage device?
Hi Bro one of my friend using iphone 12 128gp is there any device or adapter to transfer the photos from her device to storage device. Purchased 200gb cloud that too insufficient then moved to 1TB. Please suggest any devise so she can move all the photos from cloud and phone storage.
Also is this possible to increase iphone storage from 128gb to 256 r 512 gb. if yes please suggest how we can increase
hi bro, for 12 model we need to consider the lightning to USB A adapter. so that we can transfer to SSD storage after moving the photos, videos to files app. At third party service center who do chip level service, they may upgrade storage bro. we have to do it with our own risk. over upcoming software updates if there is any issues we need to check again with same service center.
To avoid putting our data at risk, we need to take regular backups to local storage or cloud storage if decided to change internal storage bro.
Can you suggest any brand which support iphone lighting to usb adaptor which us reliable in market. This can be used only with ssd
I have reviewed one in our channel bro but sadly it wont work with SSD. my mistake, we have to try transferring to computer using 3utools type of app first. Then to SSD.
OTG adapter I have suggested is not compatible with SSD.
