Sudden battery drop in iPhone 14
Bro my iPhone 14 had a sudden battery drain and for no reason pls help
hi bro, in low signal coverage areas when we use apps like insta, youtube for video streaming, battery consumption will be higher bro. if it has full signal strength or connected to wifi, battery consumption will be bit less.
do try this tomorrow morning till evening and share the screenshot bro. dont charge in between till it reaches 20%. that will help us to understand according to your usage.
Hi bro here is the graph
and battery health:97 after 2months bought it January
as you can see idle graph is good and when usage happens in mobile data, it starts to reduce gradually. mostly instagram consumed more battery power. just for 2 days you can uninstall instagram app and use it in safari browser bro. you will see huge difference in battery power. other than that, its totally normal.
What about battery health
How much battery health reduced bro? kindly mention the month of purchase.
Battery health:97
Month of purchase: January
3 months 3% reduce bro. its normal. some months it wont reduce. continue following the charging practice and it will help.
