Suggest 14" MBP screen protector brands
Suggest some good screen protector brands for 14" MBP
Unfortunately, there is no 14 inch screen protector available on amazon bro. the one I reviewed in our channel for 13 inch macbook air Saco screen guard also available for 14 inch model. But not much user reviews and with one bad review at present.
https://amzn.to/3XQGxCZ
Do check with any local mobile or laptop shops in your city too bro. some people provide custom cut out screen protectors too. Ultimate thing is, to make sure its a slim screen guard to avoid any issue when we close the lid. it shouldn’t be too thick.
Actually I bought spigen screen protector with 9H hardness and after that I saw your video in utube.
Can I apply it ?
If you have already bought it, then use it bro. dont worry. Avoid using keyboard sleeves and see whether it lets you close the lid perfectly. clean the display surface very well with provided alcohol pads and in clean room environment bro.
